REFFRENCE MANAGER
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11010
Printed Date: 28.Oct.2026 at 21:56
Topic: REFFRENCE MANAGER
Posted By: ktahameed
Subject: REFFRENCE MANAGER
Date Posted: 24.Feb.2015 at 14:08
IN WINDOWS 8 HOW TO USE REFERENCE MANAGER FOR AUTO CAD. ACTUALLY I WANT TO CHANGE ALL XREF IN ONE FOLDER TO ANOTHER
------------- ABUASHIKA
Posted By: John Connor
Date Posted: 24.Feb.2015 at 14:41
What does the OS version have to do with Reference Manager? If you have AutoCAD 2015 loaded then the Reference Manager should already be listed under Start > All Programs > AutoDesk > AutoCAD 2015. Did you try running it?
By the way, there is no need to capitalize each and every word in a sentence. It is considered bad form.
How to use Reference Manager.
http://autodesk.blogs.com/between_the_lines/2013/03/autocad-reference-file-management.html
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 25.Feb.2015 at 08:28
Thank you for your information. it is usefull
