printing problems with a layout
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11201
Printed Date: 29.Oct.2026 at 08:07
Topic: printing problems with a layout
Posted By: JoseDomingo
Subject: printing problems with a layout
Date Posted: 04.Jun.2015 at 08:13
autocad 2012-64bit under windows 7-64
When try to print the program hangs or the printing lasts too much time
How can i depure this problem ?
Best Regards
------------- http://ingenierostenerife.blogspot.com.es http://peritostenerife.wordpress.com
Posted By: John Connor
Date Posted: 04.Jun.2015 at 11:28
Not enough useful information to pinpoint the problem.
Could be a printer driver problem.
Could be your drawing needs to be cleaned up (Overkill, -Purge, Audit).
Could be AutoCAD is searching for something and can't find it.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: philippe JOSEPH
Date Posted: 04.Jun.2015 at 12:39
Hello JoseDomingo, it could be a problem of .CTB location, if it's not on your disk it delays the print.
Tell us if you know about CTB or not.
Posted By: divyakumar
Date Posted: 08.Jun.2015 at 10:47
Is there any problem in printing the drawing without layout? If no, Then the printer will be the problem.
Date Posted: 11.Jun.2015 at 03:02
May be the third. I have purged the draw but continues
printer driver ? No, i don't think so.
Tell us if you know about CTB or not. |
this may be. I will investigate and comment Best Regards
Date Posted: 11.Jun.2015 at 03:05
By the way.
Happen with other programs like DraftSight too.
I think may be cbt relationship.
Date Posted: 11.Jun.2015 at 03:26
May be inside the drawing or autocad file.
happen in other pc.
Date Posted: 11.Jun.2015 at 03:45
I have the plotstyles.
acad.ctb
Date Posted: 11.Jun.2015 at 03:53
The problem continues
Date Posted: 11.Jun.2015 at 11:27
If it happens with both programs then I'd be more inclined to think it was a printer driver issue.
<<AutoCAD 2015>>
Date Posted: 22.Jun.2015 at 15:11
Other entities i can investigate ?
It's not a printer driver because happen with the file, not with the pc.
Best Regards
Date Posted: 22.Jun.2015 at 16:46
Well I guess we are in disagreement then. Good luck sorting it out.
Unless you want to share the drawing with us by uploading a copy then diagnosing the problem will be difficult.
<<AutoCAD 2015>>
Date Posted: 23.Jun.2015 at 04:32
The drawing is personalyzed with my full name and data, and the data of a customer. No possible to share.
Date Posted: 23.Jun.2015 at 11:48
Strip the information out and upload the drawing. What's so difficult about that? Do you want to solve the problem or not? Seems you are making this more difficult than it has to be.
<<AutoCAD 2015>>
Date Posted: 23.Jun.2015 at 20:34
I can send to your private mail. I will try a private message.
Date Posted: 23.Jun.2015 at 20:36
Can i have an email for contact in anyway.
Mine for this purpose is
aprendoingenieros@yahoo.es
Best Regards
Date Posted: 25.Jun.2015 at 17:12
sorry.
Best Regards
I continue with my problema and i will try to solve in any place able and ready to help me.
Date Posted: 25.Jun.2015 at 19:39
I sent you an email yesterday using the address you posted but never received a reply.
<<AutoCAD 2015>>
Posted By: jmontesmx
Date Posted: 02.Jul.2015 at 02:57
Your printer is directly connected or network, if this network then Check the IP address of your printer.
