Print Page | Close Window
Blocks Basepoint
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11215
Printed Date: 25.Oct.2026 at 15:38
Topic: Blocks Basepoint
Posted By: domnanan
Subject: Blocks Basepoint
Date Posted: 13.Jun.2015 at 10:52
Hi All,
Is it possible to change the basepoint of a block without the block resulting in the displacement of the latter on the drawing.
I usually have to replace blocks created by others with the basepoint being mis-placed on the latter. Using "Replace block by another block" is much helpful, except that the dispoints neglected by others sends my new blocks far away from my drawing. An add-on of it may save so much time in my drawing process all day long.
Thanks
DSN
Posted By: John Connor
Date Posted: 15.Jun.2015 at 13:06
One method explained here...
https://www.augi.com/library/quick-tip-how-to-change-the-insertion-point-of-a-block
<<AutoCAD 2015>>
Posted By: domnanan
Date Posted: 15.Jun.2015 at 21:31
Went through the site.http://www.cadforum.cz/forum_en/smileys/smiley2.gif It wasn't of great help since this method still displaces the blocks of same name when moving the entities to the ucs (new base point) in the block editor. Seems that this practical command doesn't exist. However, it is practically quite intensely required while changing the blocks of a drawing to standard.
Unless moving the blocks after editing; N.B that those blocks with -ve scale moves in opposite direction. Thanks anyway.
DSN
Posted By: Kent Cooper
Date Posted: 16.Jun.2015 at 20:30
There's a routine that's meant to do that, including compensating for insertion points and scales and rotations in already-existing insertions so that they visually stay where they are, http://cadtips.cadalyst.com/edit-blocks/redefine-block-insertion-point" rel="nofollow - over here .  I have tried it just a very little, and it seems to work, but I haven't tested it in lots of different situations.
