The assembly cannot be solved, Need Help!
Printed From: CAD Forum
Category: EN
Forum Name: Inventor
Forum Description: Discussion about Autodesk Inventor
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11230
Printed Date: 19.Jul.2026 at 18:11
Topic: The assembly cannot be solved, Need Help!
Posted By: MrZortrax
Subject: The assembly cannot be solved, Need Help!
Date Posted: 27.Jun.2015 at 13:19
Hi there,
im to stupid to assambly parts i need some backup right now! I dont have any idea where is a mistake.
For example i have a Cube with a table in the middle like a 3D Printer. On the Left and Right side of the Cube are 2 sliders on each side and this sliders should be join with one table to drive up and down.
This works only with one side of the sliders. If i do Join the Hole on the Table to the screw on the slider1 and choose rigid and choose the right direction of the part, thats works and is okay for now. The slider1 drives with the table up and down. so far so good. Now try the same thing with the secound slider, but i get every time the message The assembly cannot be solved ( The new relationship conflicts with existing assembly relationships. )
I hope anyone can help me. I use the Command Join to connect this parts.
Thank you.
