Print Page | Close Window
Problems commands ACAD.pgp
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11251
Printed Date: 05.Sep.2026 at 04:16
Topic: Problems commands ACAD.pgp
Posted By: Sandervp
Subject: Problems commands ACAD.pgp
Date Posted: 09.Jul.2015 at 11:51
if I use some commands, in AutoCad 2015,  they don't do the command  which is listed in the acad.pgp file.
For example; If I want to stretch something, I (normally) use the "s" button. But if I push the "s" button at this moment. AutoCad shows me the settings window.
If I open the acad.pgp, I see that the "s" command stands for stretching, not for settings.
This Acad.pgp file is the only one on my pc.
How is this possible?
ps. first week I'm using AutoCad 2015..
Posted By: John Connor
Date Posted: 09.Jul.2015 at 12:00
You have to teach AutoCAD to use the command.  Type "S" then look at the AutoComplete display in the lower left hand corner of your screen.  Select the Stretch command from the list.  Now the next time you use "S" the Stretch command should become the default.
<<AutoCAD 2015>>
Posted By: Sandervp
Date Posted: 09.Jul.2015 at 12:06
But if I want to use the "REA" (regenall) command, it doesn't list there.
Also, the AutoComplete display, doesn't appear every time even if I wait for a few seconds..... If I use a command, at the moment that the AutoComplete display doesn't appear, the command is unknown.
Date Posted: 09.Jul.2015 at 23:26
Did you just recently install the program?
Type INPUTSEARCHOPTIONS at the command line then press the Enter key.  Look at the dialog box.  Note the options that are available and what your current setting are.  Change the settings to suit your needs.
The first two options you might want to change are AutoCorrect re: number of mistypes and the delay time.
<<AutoCAD 2015>>
