corrupt file? "program has exceeded capacity"
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11316
Printed Date: 22.Oct.2026 at 01:32
Topic: corrupt file? "program has exceeded capacity"
Posted By: AGALA
Subject: corrupt file? "program has exceeded capacity"
Date Posted: 12.Aug.2015 at 21:06
i am using rebarcad 2004 (yes i know thats old). i keep having trouble because when i try and go to the barlist it keeps saying "unable to schedule, program has exceeded capacity." i think my file has been corrupted. has anyone seen this before? or does anyone have any tips on how to fix a corrupt file? i have already tried audit and purge commands :( it did not work
------------- AGALA
Posted By: John Connor
Date Posted: 13.Aug.2015 at 11:26
Does the program have a RECOVER command?
Can a rebarCAD drawing be opened in AutoCAD?
If so, does AutoCAD 2004 have a RECOVER command?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: AGALA
Date Posted: 13.Aug.2015 at 14:12
recover command works but when i bring in the file to the new drawing, the problem was not fixed.
------------- AGALA
Date Posted: 13.Aug.2015 at 14:34
If that is the case then you most likely have a corrupted file.
Did you try inserting it into a new drawing?
<<AutoCAD 2015>>
