Print Page | Close Window
[HELP] 3D Ergonomic Cup
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11329
Printed Date: 05.Sep.2026 at 00:02
Topic: [HELP] 3D Ergonomic Cup
Posted By: infernowheels
Subject: [HELP] 3D Ergonomic Cup
Date Posted: 22.Aug.2015 at 17:06
I have designed the Cup part, however I'm having a hard time on how to approach the handle part of it. I plan to design it in 2D and then use revolve, but I'm stuck on the 2D part... problem is that since I have no idea at which part to start and how to make sure that I get accurate curves. I guess I can make circles with the given radiuses but putting them together is where I'm stuck at.
Any help would be greatly appreciated, Thanks!
<Autodesk AutoCAD 2016>
uploads/580226/CT213-JUMAWANCARLJAMES_ERGONOMIC_CUP.dwg" rel="nofollow - uploads/580226/CT213-JUMAWANCARLJAMES_ERGONOMIC_CUP.dwg
Posted By: John Connor
Date Posted: 23.Aug.2015 at 22:49
Could you explain your design intent?  Not sure I understand what this ergonomic handle is supposed to look like.  And what is it that make it "ergonomic" in the first place?
<<AutoCAD 2015>>
Posted By: philippe JOSEPH
Date Posted: 24.Aug.2015 at 07:42
http://www.cadforum.cz/forum_en/uploads/175428/CT213-JUMAWANCARLJAMES_ERGONOMIC_CUP_PJH.dwg" rel="nofollow - uploads/175428/CT213-JUMAWANCARLJAMES_ERGONOMIC_CUP_PJH.dwg
Hello infernowheels, please find here a solution + explanations.
Let us know if this helped or not.
Date Posted: 24.Aug.2015 at 11:24
I'm still puzzled as to why the cup would be considered ergonomic.
<<AutoCAD 2015>>
