working as CAD designer
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11337
Printed Date: 06.Nov.2026 at 11:34
Topic: working as CAD designer
Posted By: 35889
Subject: working as CAD designer
Date Posted: 26.Aug.2015 at 23:43
I am a mechanical engineering graduate who wants to work as a CAD engineer. Is there anybody on here who can fill me in on what to expect? I am certified with inventor, used it for over 5 years but have not touched autocad. I dont know much about drafting in terms of part and assembly drawings in real life projects, and im not really sure on what to expect from a CAD engineering job based in mechanical projects. Is there anybody who could give me some insight into aspects of the job as a CAD engineer, and how a project starts and finishes in terms of part, assembly drawings and use of software etc? Thanks for any replies.
Posted By: jnem
Date Posted: 27.Aug.2015 at 08:23
I have not worked as a CAD Designer for long but from the experience that I have, you need to do learn Autocad. Majority of projects out there require 2D technical drwaings and Autocad is a leader in this. You can also look for projects involving product designs and developments which mostly use inventor or such close softwares.
------------- jmn
Posted By: John Connor
Date Posted: 27.Aug.2015 at 11:31
No such thing as a cad engineer. There are cad techs and cad managers however. There are also engineers who use cad as a tool much as they would use a calculator or a spreadsheet.
Large well established companies are moving away from using generic AutoCAD towards such programs as Revit. Revit is considered to be a "modern" cad program and is nothing like AutoCAD. I suggest you look into Revit MEP. Start with this link...
http://www.autodesk.com/products/revit-family/overview
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: nishajanarthan10
Date Posted: 22.Sep.2015 at 11:07
Working with CAD for a project is so easy. You just learn the basics of CAD and its shortcuts. This will help you to finish projects quickly. Start learning more about the shortcut keys.
Date Posted: 22.Sep.2015 at 11:44
I fail to see what vital information that ^ ^ ^ post imparted to the OP. How does learning shortcut keys benefit someone doing mechanical design using CAD? What do shortcut keys have to do with parts and assembly drawings?
<<AutoCAD 2015>>
Posted By: thomas rydder
Date Posted: 22.Sep.2015 at 14:24
Whew...there's a guy who bears watching while at work, eh John?
------------- Tom
Date Posted: 22.Sep.2015 at 23:46
I'm sure he could teach us a trick or two about shortcut keys.
<<AutoCAD 2015>>
