Add multiline text with Attedit
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11495
Printed Date: 06.Sep.2026 at 03:48
Topic: Add multiline text with Attedit
Posted By: rohgahh
Subject: Add multiline text with Attedit
Date Posted: 25.Nov.2015 at 15:25
Hi
I have a template and there are 3 blocks with text 1000, 1001, 1002
With a script, I can change them with attedit to the numbers I want. However, one off them i need to change to:
To sheet 101
just like that, with an enter.
>> "D:\change_frame\scripts\auto_pag.scr" echo -attedit >> "D:\change_frame\scripts\auto_pag.scr" echo( >> "D:\change_frame\scripts\auto_pag.scr" echo( >> "D:\change_frame\scripts\auto_pag.scr" echo( >> "D:\change_frame\scripts\auto_pag.scr" echo( >> "D:\change_frame\scripts\auto_pag.scr" ECHO 410,291.0 >> "D:\change_frame\scripts\auto_pag.scr" ECHO -40,-40,0.0 >> "D:\change_frame\scripts\auto_pag.scr" echo. >> "D:\change_frame\scripts\auto_pag.scr" echo V >> "D:\change_frame\scripts\auto_pag.scr" echo C >> "D:\change_frame\scripts\auto_pag.scr" echo 1002 >> "D:\change_frame\scripts\auto_pag.scr" echo To sheet 101
With this code, it will be all in one line.
What do I have to do to write like I want to?
Thanks in advance
