block visibility
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11660
Printed Date: 03.Sep.2026 at 19:47
Topic: block visibility
Posted By: gegenytibor
Subject: block visibility
Date Posted: 24.Feb.2016 at 10:01
Hello guys!
I have a block with 6 visibility which I can change easyli with the drop-down list. It works well. But if I change the scale of the block it lose the drop-down list. In the block editor I can see the 6 different states but no drop-down list in the model space. Why?
Could you help me? Do you have any ideas?
thank you for the answer! T
Posted By: John Connor
Date Posted: 24.Feb.2016 at 11:29
It would help if we had a copy of the block to play with.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Date Posted: 24.Feb.2016 at 12:03
Of course! Here is the block. uploads/341466/block.dwg" rel="nofollow - block.dwg
If I change the scale on the properties panel (Ctrl + 1) I lose the drop-down list. But If I use the "Scale" command then I will have drop-down menu after the scaling as well.
Date Posted: 24.Feb.2016 at 12:41
So you can scale the block after all just not by using the Properties palette.
Well I just tested your block using AutoCAD 2015 and changing the X, Y and Z scales in the Properties palette to .5 and I did not lose the drop-down list. You must have done something unusual.
<<AutoCAD 2015>>
Date Posted: 24.Feb.2016 at 14:11
Thank you!
I will use the scale command.
have a nice day!
Date Posted: 24.Feb.2016 at 14:24
Well that is an option too.
When you went through the Properties palette did you change all three scales (X, Y, and Z) or just X and Y?
<<AutoCAD 2015>>
Date Posted: 24.Feb.2016 at 15:10
Hello John,
You find my misstake! I changed only the X and Y scale and not the Z.
thank you again!
Date Posted: 24.Feb.2016 at 15:14
Some times it is the littlest things that trip us up.
You're welcomed.
<<AutoCAD 2015>>
