Print Page | Close Window
Invalid Input error while assign configure value
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11740
Printed Date: 31.Oct.2026 at 06:07
Topic: Invalid Input error while assign configure value
Posted By: PrasadUddanti
Subject: Invalid Input error while assign configure value
Date Posted: 05.Apr.2016 at 11:33
Hi I am using Autocad 2014 API
while developing Autocad application i am getting some errors
while assign plotter value (HybridConverter.pc3)to comfigname getting invalid input error message .please help on that
Please see the below VB.Net Code
Dim rasterObj As Autodesk.AutoCAD.Interop.Common.IAcadEntity
Dim Layout As Autodesk.AutoCAD.Interop.Common.AcadLayout
Dim l_SheetCount As Integer
Dim NewFile, codespot As String
Dim i As Integer
Dim resume2 As Boolean = True
Try
codespot = "SAP 1"
NewFile = "monochrome.ctb"
l_SheetCount = CInt(clsVariable.DrawingSheet)
codespot = "SAP 2"
Layout = Acad.ActiveDocument.ModelSpace.Layout
codespot = "SAP 3"
rasterObj = Layout.Block.Item(l_SheetCount - 1)
If Not (Layout.CanonicalMediaName = "ANSI_E_(44.00_x_34.00_Inches)") Then
End If
Layout.PlotRotation = Autodesk.AutoCAD.Interop.Common.AcPlotRotation.ac0degrees
codespot = "SAP 5"
If Not (Layout.StyleSheet = NewFile) Then
If Not (Layout.StyleSheet = NewFile) Then ''if the style sheet can't be set, use none
Layout.StyleSheet = ""
End If
End If
codespot = "SAP 6"
Layout.PaperUnits = Autodesk.AutoCAD.Interop.Common.AcPlotPaperUnits.acInches
codespot = "SAP 7"
Layout.StandardScale = Autodesk.AutoCAD.Interop.Common.AcPlotScale.acScaleToFit
codespot = "SAP 8"
i = 0
'Layout = Acad.ActiveDocument.Layers.Add("Junk") 'commented prasad
'Set the layer named "Junk" the active layer for the current document
Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("Junk")
Acad.ActiveDocument.ActiveLayout.PlotType = Autodesk.AutoCAD.Interop.Common.AcPlotType.acExtents
Acad.ActiveDocument.ModelSpace.Layout.ConfigName = "HybridConverter.pc3" --Getting Error in this line
''Acad.ActiveDocument.Regen acActiveViewport
Acad.ActiveDocument.ModelSpace.Layout.RefreshPlotDeviceInfo()
Acad.ActiveDocument.ActiveLayer = Acad.ActiveDocument.Layers.Item("0")
Layout = Acad.ActiveDocument.Layers.Item("Junk")
Layout.Delete()
codespot = "SAP 9"
Application.DoEvents()
Acad.Update()
