Pick box and cross hair separation
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11770
Printed Date: 05.Sep.2026 at 08:47
Topic: Pick box and cross hair separation
Posted By: Mark A
Subject: Pick box and cross hair separation
Date Posted: 19.Apr.2016 at 06:45
I am working with an imported survey dwg and as I zoom in very close the cross hair position on screen separates from the pick box in the Z direction and it becomes extremely difficult to select a point on any object. I don't know how to fix this issue and am becoming very frustrated in this file. I have tried importing the work into another file but the problem comes with it. Any help would be appreciated.
Posted By: John Connor
Date Posted: 19.Apr.2016 at 11:25
Not sure how that is even possible. Sounds like a graphics problem to me.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: Mark A
Date Posted: 20.Apr.2016 at 01:52
It only happens in this file or with the imported data from the file I received. I've never seen it before either and I have been using AutoCAD for 20 years.
Date Posted: 20.Apr.2016 at 11:24
Have you tried cleaning the file up?
<<AutoCAD 2015>>
