Print Page | Close Window
hatch dialog box does not show
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1178
Printed Date: 05.Sep.2026 at 10:37
Topic: hatch dialog box does not show
Posted By: enemigoman
Subject: hatch dialog box does not show
Date Posted: 07.Oct.2008 at 18:48
Hello:
I am using ACAD 2007 and all of a sudden the hatch command stopped working.
The problem is that the dialog box doesn't show.  Whenever I type 'hatch' or 'bhatch' or use the button from the toolbar, I can see in the Command Line" that the command itself is recognized (no error or anything), but the dialog box does not show and I am immediately free to use other commands.  There is no "cancel" message of any sort either.
Other commands with dialog box do work properly.
Thanks
Posted By: Arben.Allaraj
Date Posted: 08.Oct.2008 at 14:47
Originally posted by enemigoman enemigoman wrote:
Hello:
Thanks
Maybe you should check FILEDIA variable.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
