Print Page | Close Window
Can't change color, lines in layer AutoCAD 2007
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11958
Printed Date: 17.Jul.2026 at 04:45
Topic: Can't change color, lines in layer AutoCAD 2007
Posted By: Midhat
Subject: Can't change color, lines in layer AutoCAD 2007
Date Posted: 11.Aug.2016 at 09:03
Hello,
I have a problem with my AutoCAD 2007, when I want to create new layer I can't change color, line type, lineweight, except the name of the layer. When I want to change color I choose the color I want but when I select it and pressed OK, nothing has changed, the color is still white, and same case is with the line type and lineweight.
Thank you for your help.
Kind regards
Posted By: John Connor
Date Posted: 11.Aug.2016 at 11:36
When did this problem first occur?
Does the problem occur even when you start a new drawing?
Have all service packs been installed?
What steps have you taken thus far to troubleshoot the problem?
<<AutoCAD 2015>>
Posted By: Midhat
Date Posted: 11.Aug.2016 at 12:19
I just installed CAD, and first time I wanted to make this changes, to make layers, problem occurs.
Yes it occurs even when I start new drawing, and all services packs are installed.
I tried command purge and audit, but without success.
Date Posted: 11.Aug.2016 at 13:25
This wouldn't happen to be a pirated copy of AutoCAD 2007 by any chance is it?  Well if it is then you got what you paid for.  If it isn't then try doing a REPAIR of the installation.  A REPAIR is NOT the same as an uninstall / reinstall.  It only takes a few minutes.
<<AutoCAD 2015>>
Posted By: Midhat
Date Posted: 11.Aug.2016 at 15:15
It's not pirated version of AutoCAD, thank you for your help.
Date Posted: 11.Aug.2016 at 15:24
Well that's encouraging to know.
<<AutoCAD 2015>>
