Print Page | Close Window
HATCH .PAT File Format
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11990
Printed Date: 06.Sep.2026 at 01:30
Topic: HATCH .PAT File Format
Posted By: ef_guerra
Subject: HATCH .PAT File Format
Date Posted: 26.Aug.2016 at 17:02
Want to create hatch *.pat file, open an preexisting file, a functional pattern file, whit notepad, no modification done & saved as *.pat extension (other name to avoid damage to original) and AutoCAD says (for the new one) "error in pattern file". Any idea to solve it? (None of the 4 encoding options from notepad work)
(Currently using AutoCAD Architecture 2017)
Posted By: Kent Cooper
Date Posted: 27.Aug.2016 at 04:57
Is it a one-pattern .pat file?  If so, the name of the file [+ the .pat] must be exactly the same as the pattern name.  So if you change the name of the file, change the name of the pattern defined in it, to match.
