Print Page | Close Window
Poly line joining
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11991
Printed Date: 05.Sep.2026 at 06:11
Topic: Poly line joining
Posted By: waynelem
Subject: Poly line joining
Date Posted: 29.Aug.2016 at 00:03
Let's say I draw one a poly line horizontal and the next vertical some distance apart. When I use a 90deg chamfer to make a corner the lines are then joined as one. Is there a way to stop this as I would still like them to still be seperate lines?
Wayne
wayne
Posted By: waynelem
Date Posted: 29.Aug.2016 at 18:34
So this can't be done?
wayne
Posted By: philippe JOSEPH
Date Posted: 30.Aug.2016 at 07:16
Hello Wayne, if you don't want the polylines to be united ( in one polyline ) then use the command LINE and not POLYLINE or you can explode the polyline.
Posted By: waynelem
Date Posted: 30.Aug.2016 at 19:26
I need to show line width and if I explode the width is gone.
wayne
Posted By: Robert_D
Date Posted: 30.Aug.2016 at 20:06
"BREAK" the polyline @ intersection?
Posted By: waynelem
Date Posted: 31.Aug.2016 at 00:55
That is what I have done in the past. Just an extra step.
Still hard to believe that you can't stop the joining in the first place.
Thank
wayne
Posted By: Robert_D
Date Posted: 31.Aug.2016 at 16:29
Rather than CHAMFER, use EXTEND?
Posted By: waynelem
Date Posted: 01.Sep.2016 at 01:03
Done that.
Thanks
wayne
Posted By: Kent Cooper
Date Posted: 01.Sep.2016 at 16:41
Try PolylineSubdivide.lsp with is PSD command, available http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/polyline-width-to-polyline-making/m-p/2660307#M288204" rel="nofollow - here .  It will at least reduce your "extra step" to one command with a simple object selection, instead of your needing to select the Polyline, specify the First option and give it the corner twice [or even the selection and the corner pick if you have a built-in-First-option routine], or do multiple single-point Breaks if you have non-zero Chamfer distances.
Of course, if you break them up like that, they will lose the angled ends that the Chamfered single Polyline has at the corners.
Posted By: ktahameed
Date Posted: 05.Sep.2016 at 11:28
THANKS KENT
ABUASHIKA
