Print Page | Close Window
changing reference plane while changing profile
Printed From: CAD Forum
Category: EN
Forum Name: Revit
Forum Description: Discussion about the BIM application Autodesk Revit (Architecture, Structure, MEP), Autodesk Forma
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12010
Printed Date: 28.Sep.2026 at 11:36
Topic: changing reference plane while changing profile
Posted By: henk-hjk
Subject: changing reference plane while changing profile
Date Posted: 13.Sep.2016 at 11:43
Hi there,
While changing the profile (edit profile) in a sweep it seems unpossible to change the actual reference plane. (I don't mean the working plane but only the refeence plane where the profile is edited) Is there a way to change the actual reference plane. I m used to change the profile in sections and it is time consuming to place the sections in front of the actual reference plane of the profile. See image.
