Print Page | Close Window
Xref in multiple files
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12055
Printed Date: 06.Sep.2026 at 04:53
Topic: Xref in multiple files
Posted By: aqeel222
Subject: Xref in multiple files
Date Posted: 10.Oct.2016 at 07:23
Is it possible to make xref of 1 cad file in multiple files in same time.
Posted By: philippe JOSEPH
Date Posted: 10.Oct.2016 at 08:01
Yes aqeel222 xref are made for this.
You make a file to be used in different files and each time you update it, it will be updated in each file were it is xrefed.
Xref are great but you have to be careful not to rename tem, change the name of the directories, move them, etc...
Posted By: aqeel222
Date Posted: 10.Oct.2016 at 08:49
sorry dear may be I did not explain my question properly, I like to attach xref in one shot to multiple files. suppose that I have 100 file and I like to attach sheet title to all of them together. is there any short way.
Posted By: John Connor
Date Posted: 10.Oct.2016 at 16:43
Yes, create and run a script that will batch process a folder full of drawings.  Each drawing will be opened, revised and saved as the script works its way through the folder until the last drawing has been revised.
<<AutoCAD 2015>>
