Customize line or rectangle name
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12077
Printed Date: 03.Nov.2026 at 16:29
Topic: Customize line or rectangle name
Posted By: jp01202
Subject: Customize line or rectangle name
Date Posted: 21.Oct.2016 at 07:44
I have requirement to name any line or rectangle by custom name. To make it clear, I will exlain. I want to extract the area of about 100 rooms in a building. For each room, I want to draw a rectangle or a polyline with the name of corresponding room so that I can extract area of rectangle for corresponding room in excell sheet. In the output of excell file, I want the rectangle with the name of corresponing room.
Posted By: John Connor
Date Posted: 21.Oct.2016 at 10:40
I'd start with one of the many custom lisp routines that allows a user to obtain the area of an enclosed object. Modify it to also include the room name. The next step would be extract the data to a spreadsheet.
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
