Print Page | Close Window
DWG Blocks
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12287
Printed Date: 31.Oct.2026 at 06:07
Topic: DWG Blocks
Posted By: AndrzejBor
Subject: DWG Blocks
Date Posted: 12.Apr.2017 at 19:36
I am new on this forum and new to DWG format.
What is the meaning of Blocks in DWG (for example, compared to old Microstation DGN files?
Posted By: johnnybburn72
Date Posted: 12.Apr.2017 at 19:40
I'm not familiar with the software you mentioned in your post; however, the context in which I use blocks - they are objects that you can manipulate and add to a drawing with and with out attributes.  I have a library of blocks drawn in individual sheets and I extract those and drop them into new drawings as opposed to drawing something from scratch every time.  An example would be compasses and symbols.
John Blackburn
Date Posted: 12.Apr.2017 at 20:03
Now I view program Ivan Explorer and IvanSampleR27.dwg - it seems that all drawing entities are grouped by Block.
Posted By: Kent Cooper
Date Posted: 12.Apr.2017 at 20:37
Help [here for AutoCAD 2017, but this topic won't be much different in other versions] will tell you http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-2DA2ADA1-C8CC-4E61-9598-06580FFD3544" rel="nofollow - about Blocks .
