Print Page | Close Window
Setup Mulltiple Viewports
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12289
Printed Date: 21.Oct.2026 at 04:37
Topic: Setup Mulltiple Viewports
Posted By: Tankman
Subject: Setup Mulltiple Viewports
Date Posted: 12.Apr.2017 at 22:50
Setup multiple VPORTS years ago. Now can't seem to get it correct.
I only use model space and paperspace.  Cry
Tankman
"When the well's dry, we'll all know the value of water."
Posted By: John Connor
Date Posted: 13.Apr.2017 at 14:58
Paper space viewports can be set up using the MVIEW command.  I'd recommend creating a separate layer for your viewports and designate them as "no print" in the Layer Properties Manager.  That way they will appear on your screen yet not be printed.  I would also recommend that once a viewport is set up the way you want that you lock the display so the viewport scale won't be inadvertently changed.
<<AutoCAD 2015>>
