properties
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12298
Printed Date: 05.Sep.2026 at 04:17
Topic: properties
Posted By: waynelem
Subject: properties
Date Posted: 20.Apr.2017 at 19:22
I am using AutoCad 2012 and when open the properties icon the x that I would click on to close is gone. I now have to click on the top and then I have to click "close". What happened and can I get it back? Thanks Wayne
------------- wayne
Posted By: John Connor
Date Posted: 20.Apr.2017 at 19:46
Terminology.
Are you talking about the Properties Palette?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: waynelem
Date Posted: 21.Apr.2017 at 23:00
Using Classic icons, yes I know learn the new way. Click on the icon and the drop down of the properties doe not have the X in the top corner to close. Wheen I click in the empty area at the top I get a box with the word close. So much slower. Wayne
------------- wayne
Date Posted: 23.Apr.2017 at 22:38
Classic icons? OK. If we aren't talking about the Tool Palette then are we talking about the Properties icon on a toolbar?
<<AutoCAD 2015>>
Posted By: waynelem
Date Posted: 24.Apr.2017 at 00:07
Date Posted: 24.Apr.2017 at 11:49
Were you mucking around in the CUIx and messed something up?
<<AutoCAD 2015>>
Posted By: waynelem
Date Posted: 24.Apr.2017 at 17:27
Nope. Not that smart.
------------- wayne
Date Posted: 24.Apr.2017 at 17:41
Keep it simple. Run a REPAIR of the installation and that should fix the problem. It might take all of five minutes. A REPAIR is not the same as an uninstall/reinstall.
<<AutoCAD 2015>>
Posted By: waynelem
Date Posted: 25.Apr.2017 at 03:37
Thanks.
------------- wayne
