change font color of title window
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12319
Printed Date: 18.Sep.2026 at 00:59
Topic: change font color of title window
Posted By: gabrirusti
Subject: change font color of title window
Date Posted: 02.May.2017 at 15:55
hi at all on autocad 2016 is possible to change the color of the open window title?
tnks at all
Posted By: John Connor
Date Posted: 02.May.2017 at 16:19
You mean at the very top of the screen where the words "AutoDesk AutoCAD 2016" followed by the name of the drawing that is opened appears?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: Kent Cooper
Date Posted: 02.May.2017 at 19:41
If the answer to John's question is Yes, that's an operating system setting, not an AutoCAD setting. In Windows 7 that I have here [may vary in other versions], it's under Control Panel > Appearance and Personalization and in the Personalization category pick Change window glass colors. Notice not only color options, but also the "Enable transparency" checkbox and the "Color intensity" slider.
