PVC Piping blocks
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12336
Printed Date: 05.Sep.2026 at 09:21
Topic: PVC Piping blocks
Posted By: tentacle
Subject: PVC Piping blocks
Date Posted: 10.May.2017 at 16:24
Hi, there.Does anyone knows where to find a library for PVC pipes reducers,tee,elbow etc for autocad ?
Posted By: John Connor
Date Posted: 10.May.2017 at 16:53
Have you checked the CAD Blocks section of this website yet?
Blocks/symbols only have to be saved in either DXF and/or DWG file format to be inserted into AutoCAD. Check the version of AutoCAD that the blocks were created in too.
Can we assume you are working in metric units?
------------- "Humans have a strength that cannot be measured. This is John Connor. If you are reading this, you are the resistance."
<<AutoCAD 2015>>
Posted By: tentacle
Date Posted: 10.May.2017 at 17:08
Thank you for answering me. I have already checked the site, but i didnt find anything, except one file with few pcv elbows, tees, reducers (file : PVC-FITTING-ELBOWS-TEE-REDUCERS.DWG), im using a metric units
Date Posted: 10.May.2017 at 17:22
Well there are other places that you can check. One of them is the AUGI website. You might get lucky and find something there. But you will have to sign up first.
There is also this app at the AutoDESK App Store....
https://apps.autodesk.com/ACD/de/Detail/Index?id=5542906462405181104&appLang=en&os=Win32_64
The symbols are metric.
<<AutoCAD 2015>>
Posted By: Kent Cooper
Date Posted: 11.May.2017 at 16:25
Put something like "free cad blocks" into a web browser Search window, and you'll get more sites than you can ever look at. Most have categories, many have both 2D and 3D versions of things, etc., etc. You should also look into manufacturers' websites.
Posted By: tentacle
Date Posted: 12.May.2017 at 08:56
Thanks everyone for helping me. I find the George Fisher AutoCAD Library useful
