Print Page | Close Window
pergola BIM OBJECT for Revit 2017
Printed From: CAD Forum
Category: EN
Forum Name: Revit
Forum Description: Discussion about the BIM application Autodesk Revit (Architecture, Structure, MEP), Autodesk Forma
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12394
Printed Date: 21.Oct.2026 at 01:25
Topic: pergola BIM OBJECT for Revit 2017
Posted By: Kravmaga
Subject: pergola BIM OBJECT for Revit 2017
Date Posted: 19.Jul.2017 at 00:45
Hi,
where can I have a free download of a simple pergola BIM OBJECT to use in a Revit architectural model?
What about of sliding doors in glass panels Rfa. files.
How can I use them in the architectural model? I draw the Wall and tryed to put the rfa. of a glass panel in it but it did not work out.
Thanks,
Posted By: John Connor
Date Posted: 19.Jul.2017 at 11:39
I guess you did not bother with doing a search here at the CADforum in the CAD/BIM Blocks section.
Or you can do an Internet search on "pergola"+"BIM object".
Either way, you will find something.
<<AutoCAD 2015>>
