Print Page | Close Window
Style Based Plotting
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1240
Printed Date: 05.Jul.2026 at 22:56
Topic: Style Based Plotting
Posted By: hard0236
Subject: Style Based Plotting
Date Posted: 22.Oct.2008 at 17:45
I'm using AutoCAD Mechanical 2009. I am in the process of setting up a style based plotting file (stb). When I pull up the layer manager dialog box, there is no plot style column. I went to the Tools->Options->Plot and Publish Tab->Plot Style Settings... and selected the "use named plot styles" button and selected my stb file. I've also gone through the PSTYLEMODE command to make sure it was set to "0". It was set at "1 (read only)", but I proceeded with the PSTYLEPOLICY command and set it to "0". Now the PSTYLEMODE reads "0 (read only)". In the Page Setup Manager dialog box I changed the plot style to the appropriate stb and applied it to all layouts with no results as to the problem I mentioned earlier. I'll continue to search for solutions, but if someone could help I would really appreciate it.
Thank you.
Greg
