Print Page | Close Window
customized Brep for generating CAD model
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12683
Printed Date: 29.Sep.2026 at 09:22
Topic: customized Brep for generating CAD model
Posted By: Archaiser
Subject: customized Brep for generating CAD model
Date Posted: 30.Mar.2018 at 23:19
Hi All
I am trying to generate a solid CAD model from a custom surface definition, such as B-splines surfaces. Is there a tool where I can write code to generate my own B-spline surface (from scratch down to every detail), and use that exact surface definition to output a solid CAD model? Similar to something that is obtained in software like NX/Solidworks..
Thanks,
Archak
Impossibility is a concept, possibility is a vision.
Posted By: philippe JOSEPH
Date Posted: 31.Mar.2018 at 08:43
Hello Archaiser, I don't know if AutoCAD can create "smoothed" solid directly from a custom surface.
Maybe Inventor would be a better choise because it looks like more NX/Solidworks.
More of this AutoCAD doesn't work like the 2 others.
AutoCAD would be more for common steel work with square/round pipes generated under a hydraulic press along plies than "automotive" smoothed surfaces.
On the other hand you can generate sweeped solid from a surface to an other or by sweeping a surface along a path.
Eventually, see my AutoCAD file  : 3D SOLIDS 01.dwg in the CAD/BIM Blocs library here in the site.
See also The Tip 6606 : How to create AutoCAD geometry from Excel?
Eventually, place here an example of your work for us to help more efficiently.
Posted By: Vladimir Michl
Date Posted: 31.Mar.2018 at 12:12
It may be quite difficult to create B-Splines but both AutoCAD and Inventor can do this (via API).
An example of generated 3D objects (meshes):
https://www.cadstudio.cz/en/apps/3dplot/
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Date Posted: 31.Mar.2018 at 12:38
OK Vladimir, and is it possible to easily create solids from meshes?
In fact I have a complicated 3D object ( my file WORKER 01.dwg in the CAD/BIM Blocks ) that I want to pass to Solidworks and NX but as it's only a mesh ( I supose ) nothing goes to Solid or NX but the helmet that I did in real 3D solid ( and I haven't suceeded in "saving" all my AutoCAD 3D models to NX ).
