Print Page | Close Window
Tic Lisp Routine
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12740
Printed Date: 05.Sep.2026 at 22:06
Topic: Tic Lisp Routine
Posted By: giwplay1
Subject: Tic Lisp Routine
Date Posted: 25.May.2018 at 00:34
There use to be a lisp routine that would insert tics (a block) at the end of all arcs and lines selected as a crossing (rather selecting individually).  Using the label tool works ok, but not the best.  Thoughts?
G. Ira Wallace, PE, QSD/QSP
Posted By: John Connor
Date Posted: 25.May.2018 at 11:19
You're talking about the ENDTICK.LSP and the block it requires ENDTICK.DWG right?
OVERVIEW
ENDTICK.LSP inserts and aligns the ENDTICK.DWG block at the endpoint of every arc or line in a selection set. It removes duplicate ticks.
ENDTICK is useful for surveying and civil engineering plans to demarcate points of curvature, tangency, et cetera.
The default END-TICK block is a one unit long vertical line with its insertion point at its midpoint. ENDTICK scales ticks to the dimension text height (dimscale * dimtxt), so the default tick will look as big as the current dimension text height. You can make your own ENDTICK block if you prefer some custom shape or size tick.
<<AutoCAD 2015>>
