Print Page | Close Window
Autocad 2011
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=12998
Printed Date: 31.Oct.2026 at 02:29
Topic: Autocad 2011
Posted By: Phillmcdrafting
Subject: Autocad 2011
Date Posted: 14.Nov.2018 at 23:50
When I select line, the cursor is very jerky, like it is trying to lock onto a grid point . Any suggestions on how to stop this. I have just reloaded Autocad 2100 onto a new computer and as far as I know all the settings are the same. Apreceiate any help.
Phill McGowan Drafting
Posted By: philippe JOSEPH
Date Posted: 15.Nov.2018 at 07:13
Hello Phil, one clic on F9 ( snapmode OFF ) should be enough.
It goes with the GRIDMODE ON/OFF ( F7 ).
You will have an idea of how it works if you set snapmode and gridmode ON, zoom very close to the grid and try to draw a line for example.
Then you set snapmode and gridmode OFF.
Date Posted: 15.Nov.2018 at 07:51
Hi Philippe, Thanks for your help. I had already turned off grid and slaps, but I think I have now solved the problem. I went into Dynamic Input settings and unchecked "Enable dimension input where possible" this seems to have solved the problem.
Cheers Phill.
