Print Page | Close Window
Transferin dwg files to a new PC
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1306
Printed Date: 08.Jul.2026 at 18:23
Topic: Transferin dwg files to a new PC
Posted By: CadNewbie
Subject: Transferin dwg files to a new PC
Date Posted: 11.Nov.2008 at 21:41
I have DWG (Cad 2007) files that have external images and a type of  fonts I need to keep on the drawings. I bought a new PC so I need to transfer those files....but I don't know how to keep the paths of the images and the fonts so I don't loose them in the new PC....any help on this will be appreciated !
Posted By: Apeiron
Date Posted: 12.Nov.2008 at 07:15
Use eTransmit and it will take everything.
Open the drawings and use eTransmit and this AutoCad function it will collect all the information that contains your drawings and it will export in a zip file where you will see that is everything inside(xref dwgs, images, ctb,etc).
Good luck
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron - http://www.prizee.com/?refer=Apeiron
Posted By: rossassociates
Date Posted: 12.Nov.2008 at 11:06
or take a look at synctoy from Microsoft (it's a free Power Tool :) which should allow you to synchronise directories.. :)
Posted By: Arben.Allaraj
Date Posted: 13.Nov.2008 at 17:56
If this 2 computers are in network make share your folder where are your files.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Date Posted: 13.Nov.2008 at 19:19
Thanks for your input.
I have done and it works great. But I have at least 100 files.
So I was wondering if I can do it in one shot instead of e-mail 100 files.
But Thanks
Date Posted: 13.Nov.2008 at 19:38
I have done it, it works great ! But I have at least 100 files I need to transfer, so I was wondering if there is a differente way.
Thank you !
Date Posted: 13.Nov.2008 at 19:41
I will check the synctoy.
Tx !
Date Posted: 13.Nov.2008 at 19:45
Tx,
Are not in network, actually the old PC is going "out of business" I got a new PC.
Anyway I will make sure are in share with the other Pc's on the network.
Tx again
Posted By: Vladimir Michl
Date Posted: 13.Nov.2008 at 19:48
Just copy all files to the new folders and then use the RefMan tool to adjust the xrefs/images paths globally to these new folders (or to relative paths).
See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3422 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3422
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
