Print Page | Close Window
Modify fAREA
Printed From: CAD Forum
Category: EN
Forum Name: ARKANCE (CAD Studio) applications
Forum Description: Questions and discussion about applications by ARKANCE and Be.Smart - T4R, T4I, Civil Tools, DWGtext, GeoRefImg, XLSparam, FLAY, JobTime, GeoCode, TRANS, LT Extension,...
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13063
Printed Date: 02.Sep.2026 at 14:22
Topic: Modify fAREA
Posted By: yavo7789
Subject: Modify fAREA
Date Posted: 14.Jan.2019 at 10:34
Greetings,
would someone be so kind to tell me how to edit the fAREA .vlx lisp?
I don't have any experience with Visual Lisp. The Read Me file says:
You can predefine these parameters with the following LISP
variables (set before you start the command):
LISP variables:
_FAREAPREC (default: LUPREC) - e.g.:
(setq _FAREAPREC 2)
_FAREAFACTOR (default 1.0) - e.g.:
(setq _FAREAFACTOR 0.001)
_FAREASUFFIX (default " m2") - e.g.:
(setq _FAREASUFFIX " mm2")
_FLENGTHPREC (default LUPREC) - e.g.:
(setq _FLENGTHPREC 2)
_FLENGTHFACTOR (default 1.0) - e.g.:
(setq _FLENGTHFACTOR 100.0)
_FLENGTHSUFFIX (default " m") - e.g.:
(setq _FLENGTHSUFFIX " km")
_FPROP (default "Linetype") - e.g.:
(setq _FPROP "Material")
_fAreaSameLayer (default nil; change label layer to object's):
(setq _fAreaSameLayer T)
_FAREADS (default: system decimal separator) - e.g.:
(setq _FAREADS ",")
How do I do that? Could you please send me some screen shots on how it is done or post a link to where it is explained in detail? Thank you in advance!
Kind Regards
Posted By: Vladimir Michl
Date Posted: 14.Jan.2019 at 11:50
Hello,
you cannot edit the VLX file but you can use the mentioned commands to customize this application. It is simple - just copy (or retype) the LISP commands to your AutoCAD command line.
E.g. to set a 6-digits precision for fArea output, type:
(setq _FAREAPREC 6)
If you want to set it permanently, add this line to your ACADDOC.LSP file (or create new if it does not exist in your AutoCAD support path).
Vladimir Michl (moderator)
ARKANCE - https://arkance.world" rel="nofollow - https://arkance.world - Autodesk Platinum Partner
Posted By: yavo7789
Date Posted: 19.Jan.2019 at 19:55
Good evening Vladimir,
first of all thank you for the fast response. I was able to create my own acaddoc.lsp and setup fAREA as you advised. The only issue I ran into was setting up a unicode character E.g: (setq _FAREASUFFIX " ?") where ? is a cyrillic small letter m. It appears AutoCad loads only ANSI encoded .lsp files. When i setup "?" as suffix within AutoCad it works, the fAREA.vlx seems to support UNICODE characters. I also tried to work around with subscripted Capital latin letter M, but Notepad and Visual Lisp don't support subscripts as well as unicode cyrilic characters. Is there any way I can set up fAREA permanently to dysplay " ?" as suffix? Thank you in advance!
Cheers
