Print Page | Close Window
Need block plz
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13083
Printed Date: 28.Oct.2026 at 21:56
Topic: Need block plz
Posted By: anthosum
Subject: Need block plz
Date Posted: 01.Feb.2019 at 06:51
Hello guys, i search block for different thing for construction perhaps you can helped me
i search all size for IPN,IPE,UPN and UPE thanks.
Posted By: philippe JOSEPH
Date Posted: 01.Feb.2019 at 07:40
Hello anthosum, I have placed in the CAD/BIOM Blocks library here in the site 4 AutoCAD files.
They include all the blocks needed, do use them without exploding them and place them on you layers to have the color and line type that you want because inside them the lines and arcs are "by la yer" for the color and line type.
If you explode them ONE time and not TWO you will have access to regions ready for extrusion in 3D.
There are eventually other profilers that you should need, ask and I will download other files.
Posted By: ml121
Date Posted: 01.Feb.2019 at 07:49
Hi ,
You can also check the Arcelor Mitttal Website where you can find what you are looking for :
http://sections.arcelormittal.com/fr/bibliotheque/fichiers-autocad-des-sections.html ( French website )
Posted By: anthosum
Date Posted: 01.Feb.2019 at 08:48
thanks foryour answer
