Print Page | Close Window
PDF TO AUTOCAD CONVERTOR
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13402
Printed Date: 03.Sep.2026 at 13:12
Topic: PDF TO AUTOCAD CONVERTOR
Posted By: Zuhaib
Subject: PDF TO AUTOCAD CONVERTOR
Date Posted: 30.Mar.2020 at 12:23
HELLO
Hope you all are well
Please suggest me the best PDF to AUTOCAD convertor.
#stayathome #staysafe #covid-19
THANKING YOU
REGARD: ZUHAIB KHAN
Posted By: philippe JOSEPH
Date Posted: 30.Mar.2020 at 13:26
Hello Zuhaib, try : anydwg.com.
Normally it offers 30 times 3 files to convert for free.
At each convertion do a batch of three files because after the 30 times you will have to buy the product.
I do recommand not to directly use the produced DWG file but to copy/paste it into an already setted file of yours because the settings won't be correct, inches, text style, etc...
You will have to scale the entire file by using for example a very well known big dimension, use ALIGN with the option of scaling, it's very usefull.
You will have to clean  the file by erasing the entire layer defining solid hatches, take a look at the layers's names.
Maybe you will have to rotate some texts by 90 degrees, select all of them and use the properties palette to place them at the wright angle and not rotationg them one by one.
IMPORTANT : the result is not 100% precise and will be only used for general layouts.
Please tell us if this helped or not.
Force and courage for all of you.
Posted By: maalam
Date Posted: 02.Apr.2020 at 15:28
Dear Zuhaib.
You can use (Able2Extract Professional ) apk.
its the best apk to convert to DWG to PDF.
Posted By: rebellio
Date Posted: 03.Apr.2020 at 17:13
Hi Zuhab,
Perhaps PDF Import or PDF Underlay (available commands in acad 2018) are an option.
Besides that i have good experience with reaConvertor.
Keep in mind that the source (PDF) file determines the quality of the (outcome) converted file.
Regards.
Posted By: Zuhaib
Date Posted: 03.Apr.2020 at 18:22
thanx everyone.... I am going tou check all converters one by one.
THANKING YOU
REGARD: ZUHAIB KHAN
Date Posted: 03.Apr.2020 at 19:00
Hello Zuhaib and rebellio, I don't know about PDF Import but is it giving real lines and texts like anydwg or 'just' an image to eventually redraw on ?
I sometimes use this technique for 'light' studies.
Posted By: Zuhaib
Date Posted: 03.Apr.2020 at 20:39
Dear Philip,
Yes it is giving real-time line, text and hatch with its original layers.
THANKING YOU
REGARD: ZUHAIB KHAN
Date Posted: 03.Apr.2020 at 21:02
OK, Zuhaib it's very good to know because having access to a PDF and not being able to get the REAL dwg is really painfull, time consumering and leads to a lot of unprecisions.
Posted By: Zuhaib
Date Posted: 03.Apr.2020 at 22:14
Dear Philip
After converting the drawing, you will have just need to scale the drawing into mm or inch...
THANKING YOU
REGARD: ZUHAIB KHAN
Posted By: rikono
Date Posted: 10.May.2020 at 10:25
Before, some years ago, I tried to revert a pdf to dwg. The result was awful. I will try check these sites. Thanks for sharing
Date Posted: 11.May.2020 at 11:56
Yes rikono, the result is very approximate and for me it's only for a general use but it's already a miracle so we live with it and its limits.
