Print Page | Close Window
Default location for line type files
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=13721
Printed Date: 06.Sep.2026 at 18:23
Topic: Default location for line type files
Posted By: Hoffy
Subject: Default location for line type files
Date Posted: 29.Jun.2022 at 18:16
I've created some custom line types and those files are living in a personal folder but I want to move them to the default location for line types that AutoCAD Elec 22 uses. Be damned if I can figure out the convoluted paths Autodesk uses. Where are these files stored on my local hard drive? Or will that vary for different machines?
Posted By: philippe JOSEPH
Date Posted: 30.Jun.2022 at 07:13
Eventually do a search on the internet :
From what I see around, it should be in the directory : Support.
Eventually do a search on your ( C ) disk with the extention type of your line type file, .lin if I remember.
Posted By: Kent Cooper
Date Posted: 30.Jun.2022 at 13:49
Type in (findfile "acad.lin") or (findfile "acadiso.lin") and the return will show you the folder location.
