Print Page | Close Window
Secondary command screen
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14456
Printed Date: 25.Oct.2026 at 13:05
Topic: Secondary command screen
Posted By: Joker1990
Subject: Secondary command screen
Date Posted: 29.Jul.2024 at 16:30
Hello, i have this problem in my AutoCad 2024. I select some commands and when is appears the secondary command screen is appears like cutted. Somebody can help me with this? Thanks in advance
Posted By: philippe JOSEPH
Date Posted: 30.Jul.2024 at 17:53
Hello Joker1990, would what you call the secondary screen be the command line that is on the bottom of your screen ?
If yes you can change "by hand" the number of lines of it.
Try and type F2 on your keaboard to make it appear and type F2 to make it diseappear.
Tell us if this helped or not.
