Polyline by coordinates
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1503
Printed Date: 20.Oct.2026 at 03:15
Topic: Polyline by coordinates
Posted By: Shafeektm
Subject: Polyline by coordinates
Date Posted: 30.Dec.2008 at 13:45
I am facing difficulties to draw a continious polyline by cordinates in AutoCAD 2007, i use to do this in CAD 2004. can provide any support?
Posted By: Arben.Allaraj
Date Posted: 30.Dec.2008 at 16:01
Shafeektm wrote:
I am facing difficulties to draw a continious polyline by cordinates in AutoCAD 2007, i use to do this in CAD 2004. can provide any support? |
It is the same method to draw Polylines. I say tell us more exactly what you need?
------------- Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Date Posted: 31.Dec.2008 at 09:37
before you just need to type the X and Y which will draw the line for you. now ie. if i put 25,25 the line will start in the point but when you enter second point ie 15,15 it wont be in that, will go to 40,40 means it is adding the typed value with the present point. so we can only get the first point correct the remaining points will be added to the previous.
belive it is much clear now.
please feel free to write if you still confuse.
Looking forward to see from you.
Shafeek
Posted By: Ron C
Date Posted: 31.Dec.2008 at 18:23
If you are drawing a polyline relative to another point or point on an object. First start the command "pline" then pick the point that you want to start from. Then type in @25,25. This will draw a pline 25 units to the right and 25 units up. The little @ symbol is very important.
------------- RDC
Date Posted: 05.Jan.2009 at 06:32
Yes, i do try with the @ symbol also, but still for ie, your 1st point is 25,25 you will get the firet point then if you type @15,15 it wont go to the correct place, will be in 40,40 and again if you type your third point @25,25 if it is working properly it should come back to the first place. But it wont, if anybody have the 2004, you will see it will work without the @ sign.
Here this is what i an planing to draw. can anybody try to draw the pline with the following cordinates, make sure you got the correct point with the command "id"
E500643.215 N2762061.560
E500638.330 N2762069.450
E500634.325 N2762062.200
E500674.105 N2761985.390
E500670.820 N2761991.785
E500665.395 N2761986.620
E500539.645 N2762687.545
E500535.945 N2762697.720
E500546.465 N2762697.525
E500597.285 N2762559.405
E500599.485 N2762552.365
E500880.930 N2761677.805
E500882.885 N2761668.360
E500889.965 N2761674.595
E500844.885 N2761836.045
E500846.960 N2761828.715
E500855.315 N2761833.015
Date Posted: 05.Jan.2009 at 08:49
E500855.315 N2761833.015 |
Change Units of your drawings:Type Units in Command line.
Date Posted: 05.Jan.2009 at 08:52
My units in meter and i need them in meter only
Date Posted: 05.Jan.2009 at 11:55
Shafeektm wrote:
My units in meter and i need them in meter only |
yes I am agree with you ,but I mean change the Angle Type:ex-Decimal
Date Posted: 05.Jan.2009 at 13:55
Still the same. whenever i enter the second point even without @ it consider the existing point as '0' i have tried with different types of angles also. anymore update please
