Print Page | Close Window
autocad 2006 & windows vista
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1519
Printed Date: 05.Sep.2026 at 00:45
Topic: autocad 2006 & windows vista
Posted By: Inchie
Subject: autocad 2006 & windows vista
Date Posted: 06.Jan.2009 at 21:47
I am going out tomorrow to purchase a new LapTop which only comes with windows Vista. Will autocad 2006 work with this system? I currently use windows xp. Any help or advise much appreciated. cheers....
Posted By: RyBub
Date Posted: 07.Jan.2009 at 06:32
Absolutely it will work smoothly
Posted By: Apeiron
Date Posted: 07.Jan.2009 at 08:41
I don't think it will work .... only from 2008 and 2009 version you can use in Vista.
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron - http://www.prizee.com/?refer=Apeiron
Posted By: Vladimir Michl
Date Posted: 07.Jan.2009 at 09:32
You will probably find problems installing and running AutoCAD 2006 in Vista. The first Vista-compatible version is AutoCAD 2007 SP2 and 2008.
See:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5785 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5785
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: Inchie
Date Posted: 07.Jan.2009 at 13:00
Yeah it appears I will have a no. of problems so the only thing is to somehow have XP rather than Vista, or bite the bullet and upgrade to 2009 ouch...... thanks for the help
Posted By: Apeiron
Date Posted: 07.Jan.2009 at 13:05
And if you decide to upgrade to version 2009 read on Autodesk web site the requirements to work good the laptop ..... take care
Posted By: msplcdykee69
Date Posted: 08.Jan.2009 at 03:40
I am using Civil 3d 2006 and I am running it on Vista and so far it has run very smoothly.
