Print Page | Close Window
cad drawings and copyrights
Printed From: CAD Forum
Category: EN
Forum Name: CAD - general
Forum Description: General discussion about CAD, formats, standards, management, licensing, networking, harware, other CAD applications
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=154
Printed Date: 05.Nov.2026 at 01:54
Topic: cad drawings and copyrights
Posted By: mmag
Subject: cad drawings and copyrights
Date Posted: 05.Oct.2007 at 15:19
Do you know any program (aplication, lisp etc.) to protect all elements in drawing dwg against changing, copying, making new layouts.. everything without clean printing (but not to vector graphic, file) and measuring?. But I don't think about apllications like cadlock, cadvault, whitch need installing program and which does't block making new layouts. I meen sth like functions of acrobat, where I can change rights of file (f. ex. only print without password, but editing and saving as diffrent name with password)
I think about situation, when this files are often Angry using  in other designs without our  notice or agreement.
Do you have any idea? Cry
Posted By: Vladimir Michl
Date Posted: 05.Oct.2007 at 16:07
If you need to distribute DWG files, CADvault is probably the only viable and reliable option. If you need protection on a "system" level, you should publish your CAD data in the DWF format - such data are protected "by design" plus there is a password protection.
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2027 - compare PDF and DWF
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
