Print Page | Close Window
Convert lines to blocks (not: layers/entities)
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1594
Printed Date: 05.Sep.2026 at 00:03
Topic: Convert lines to blocks (not: layers/entities)
Posted By: Chipley
Subject: Convert lines to blocks (not: layers/entities)
Date Posted: 23.Jan.2009 at 16:40
Hi!
I'm a software/simulation engineer, but I'm not very well versed with Autocad. I have an Autocad layout that I am trying to convert to a simulation model. In order to do this, I need to do the following:
I have the centerline of many devices on a single layer. I need to convert all the lines on the single layer to their own layer.
Re: I need to convert all the lines on the single layer to their own blocks.
There are about 100+ lines in the layout, each of which need to be inserted into their own layer block.
Is there a batch command or method in Autocad to accomplish this task?
Thanks for any help,
~Chipley
Posted By: Vladimir Michl
Date Posted: 23.Jan.2009 at 22:27
We have prepared a tool for the original request. The Ent2Lay utility (see the Download page) will put all selected objects into individual layers.
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: awii668
Date Posted: 24.Jan.2009 at 13:03
you need to write a costom program to do the task.
http://autoCADuser-defined.com - http://autoCADuser-defined.com *
