Print Page | Close Window
Cannot save DWG
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1654
Printed Date: 05.Nov.2026 at 05:06
Topic: Cannot save DWG
Posted By: d1m4s
Subject: Cannot save DWG
Date Posted: 07.Feb.2009 at 04:28
can you help me...
i'm using autocad 2008 and i want to save as the file, but
i can not save as the file usually...
i must save as with using command...
can you help me how to save as the file without a command (show the file directory "where we want to save it")
thx
Posted By: d1m4s
Date Posted: 07.Feb.2009 at 04:49
Quote Dear readers,
The save window we are accustomed to from Windows, doesn’t appear sometimes. This is controlled by FILEDIA system variable. When the window doesn’t appear, this has somehow been turned off.
Command: FILEDIA
Enter new value for FILEDIA <0>: 1
Enter FILEDIA in the commands and change the value as 1. This should solve the problem.
Problem Solved...
thx
