Print Page | Close Window
AUTOCAD FONT
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1683
Printed Date: 24.Oct.2026 at 15:12
Topic: AUTOCAD FONT
Posted By: _Spawn
Subject: AUTOCAD FONT
Date Posted: 17.Feb.2009 at 12:26
I need to insert a new font in Autocad. I have a font named TRAJAN PRO.shx and I would like to know if anyone can help me how can I manage to insert this file in Autocad. Should i simply paste the file in the font folder(this hasn't worked for me) or is there any other procedure??
thx in advance
Posted By: CADtut
Date Posted: 18.Feb.2009 at 21:35
You need to load the font into your font folder within windows. you can then set up a text style within autoCAD.
If you need to know how to do this email me and I will go through it with you.
to insert a font within windows copy the font into the following folder:
C:\WINDOWS\Fonts
http://www.cadoutsource.co.uk - CAD Outsource
http://www.cadtut.co.uk - CAD Tutorials
Posted By: tkelly
Date Posted: 19.Feb.2009 at 09:55
You need to copy the file at two locations
1. c:\\windows\fonts
On font path of Autocad
2. c:\\program files\Autocad ...\Fonts
Restart the drawing
This should work
Tom
http://www.indovance.com - www.indovance.com
Posted By: _Spawn
Date Posted: 19.Feb.2009 at 10:36
Hi Cadtut,
Yes, I could use some help on that. I ve loaded the font both on windows and autocad folders but still doesn't work. They also have diferent extensions. one is .otf and the other is .shx. Please contact me
Posted By: bryanfuller
Date Posted: 19.Aug.2009 at 21:40
I used the method as explain by the tkelly.
