need help, axonometric 30/60
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1750
Printed Date: 05.Sep.2026 at 00:02
Topic: need help, axonometric 30/60
Posted By: muriel
Subject: need help, axonometric 30/60
Date Posted: 02.Mar.2009 at 08:00
how do you change to axonometric 30/60 view (military projection) in autocad? or it's just not possible to do so?? i found the lisp code named vojper.vlx, but i dont seem to get how to use it... can anybody help me... i'm really desperate...
Posted By: Arben.Allaraj
Date Posted: 02.Mar.2009 at 09:04
Use 3DRotate command if you want to change grade. or if you want to change scale use SCALE command with factor 0.5.
Maybe I didn't understand you.
------------- Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Posted By: muriel
Date Posted: 02.Mar.2009 at 09:13
 i want to view my 3d object, just like the picture above... "AutoCAD cannot display 3D objects in the "military projection" (30/60 axonometry). To create such axonometric view you can use the free VOJPER utility by XANADU. It projects your 3D drawing into the military projection. The military perspective (military axonometry, monometry, perspectiva caballera) uses projection angles of 30/60 degrees." i don't know how to use this VOJPER utility, can somebody help mee....
