Print Page | Close Window
AutoCAD Blocks
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1782
Printed Date: 23.Oct.2026 at 07:25
Topic: AutoCAD Blocks
Posted By: cgillis
Subject: AutoCAD Blocks
Date Posted: 10.Mar.2009 at 23:56
Any one know of a way to use a Revit block (.rfa file extension) in AutoCAD 2008? Or a way to convert the file to .dwg? Another possibility would be a elevation of a cyclist in AutoCAD (.dwg format). Dispite all the blocks available at this site the only elevation (cyclista) is a Revit file format. Thanks.
Posted By: Vladimir Michl
Date Posted: 11.Mar.2009 at 20:01
You can load RFA files into Revit and export them to DWG files (2D or 3D). There is no other "conventer".
Vladimir Michl
//CADs.cz" rel="nofollow - //CADs.cz , https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn
Posted By: cgillis
Date Posted: 11.Mar.2009 at 21:43
Thanks Vladimir. I think you created the block I am interested in (cyklista.rfa). Any chance you could export that to a 2d elevation (front & rear) and make it available on this  site?
