Print Page | Close Window
How to change the command of 'Perpendicular' ?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1829
Printed Date: 06.Sep.2026 at 21:21
Topic: How to change the command of 'Perpendicular' ?
Posted By: firelemon
Subject: How to change the command of 'Perpendicular' ?
Date Posted: 24.Mar.2009 at 06:27
Does anyone know how to change the command of Perpendicular of the OSNAP override?
I'm tired of typing 'per' when i want to perpendicular my line to another distant line. I want to change it to 'er'... involved changing the CUI file??
Thanks!
Posted By: Vladimir Michl
Date Posted: 24.Mar.2009 at 07:59
You can set PER as a persistent osnap - so you don't need to enter anything. If you have a newer version of AutoCAD you can also assign PER to one of the key overrides (with the CUI command).
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: Arben.Allaraj
Date Posted: 24.Mar.2009 at 08:44
Thanks!
Use Alias command to realise it..
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Posted By: Kajito
Date Posted: 25.Mar.2009 at 13:13
you can as well try ctrl+right click. This give you snap options ;)
