Print Page | Close Window
Contoure
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1857
Printed Date: 06.Sep.2026 at 03:47
Topic: Contoure
Posted By: Keeyhan
Subject: Contoure
Date Posted: 30.Mar.2009 at 00:00
Ca you generate contour lines by Autocad 2009?
Posted By: msplcdykee69
Date Posted: 30.Mar.2009 at 04:09
If you want AutoCAD to generate the contour lines then you will need Land desktop or civil 2009, or Civil 3D to do contours. Basic CAD will not generate those for you.
Posted By: tkelly
Date Posted: 30.Mar.2009 at 14:33
You can draft those and give elevations to that polylines so that they will work like contours. But yes, generation of contours through AutoCAD only is immpossible.
Tom
http://www.indovance.com - www.indovance.com
