Print Page | Close Window
how do i add a custom hatch pat?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1889
Printed Date: 05.Sep.2026 at 18:44
Topic: how do i add a custom hatch pat?
Posted By: 4k3el
Subject: how do i add a custom hatch pat?
Date Posted: 07.Apr.2009 at 22:05
i am new to auto cad i have read many articles but i am still very confused.
i have downloaded a thermal insulation hatch file which is in dwg format.
when i open the hatch dialoge and click on custom hatch there appears to be nothing on the list it is telling me to go to option dialoge.. files and add something there. i don't no where to add it and how.
all i want to do is use a hatch that i downloaded, how can i add it and use it?
can some one please help!Cry
Posted By: msplcdykee69
Date Posted: 07.Apr.2009 at 22:46
http://www.cadopolis.com/autocad/autocad-news.shtml - Installing hatch patterns in a few minutes
Installing AutoCAD hatch pattens is easy and takes just a few minutes. First locate a file named acad.pat and acadiso.pat (or aclt.pat and acltiso.pat for LT). Acadiso.pat and acltiso.pat are for metric hatch pattern scaling.
To begin installing your http://www.cadopolis.com/autocad_addons/COMPUGRAPHX_100 - custom AutoCAD hatch patterns first locate the hatch pattern file on your computer using the following method:
You will need to search for hidden folders in Windows. To do this first click “Start”, next click “Search”, click “All files and folders”, and then click “More advanced options”.
Next click to select the “Search system folders and “Search hidden files and folders” check boxes. In the “All or part of the file name” box type: *.pat to locate your hatch patterns file.
Once you locate the acad.pat file, right click on the file and open it with Notepad. Finally add your custom hatch pattern to the file by simply pasting the hatch pattern code.
Important step: Make sure to add a carriage return at the end of the last line. (Hit Enter to force a new blank line at the end of the code)
The order in which your http://www.cadopolis.com/solutions_list.asp?TheCategory=CatNone&TheSubcategory=SubFontsandHatch&TheKeywords= - AutoCAD hatch patterns will appear in AutoCAD is determined by the order of each pattern within the .pat file.
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Posted By: Kajito
Date Posted: 08.Apr.2009 at 09:17
I think there is an easier way ... just simply copy your *.pat file to the folder - C:\Documents and Settings\(Name)\Application Data\Autodesk\AutoCAD (version)\R18.0\enu\Support\
