Print Page | Close Window
INTERNAL ERROR:!dbobji.cpp@6762: eNotOpenFor Write
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1911
Printed Date: 23.Oct.2026 at 19:30
Topic: INTERNAL ERROR:!dbobji.cpp@6762: eNotOpenFor Write
Posted By: brenth
Subject: INTERNAL ERROR:!dbobji.cpp@6762: eNotOpenFor Write
Date Posted: 13.Apr.2009 at 21:04
Anyone have a clue what is screwed up when AutoCAD 2009 deisplays INTERNAL ERROR !dbobji.cpp @ 6762: eNotOpenFor Write
this is happening on one of the drafting computers. Any help, or suggestions would be appreciated. I suggested just re-installing CAD, but the staff member did not like that suggestion
Posted By: Arben.Allaraj
Date Posted: 14.Apr.2009 at 22:00
Apply audit command or recover .
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Posted By: brenth
Date Posted: 14.Apr.2009 at 23:03
We have tried to purge and audit the file as well as running recover on the file. nothing has changed thus far. The user started over and created a new file, and had the same problem with the new file.
(there were no other file x-refs. and both files were simple 2d)
Date Posted: 14.Apr.2009 at 23:06
Try to repair AutoCAD from control panel.
Go to control panel -->add or remove programms-->AutoCAD 2009 -->change  and choose repair.
Ing Arben.Allaraj
