Print Page | Close Window
Multi dwg to single pdf?
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2002
Printed Date: 06.Sep.2026 at 02:14
Topic: Multi dwg to single pdf?
Posted By: modicon2
Subject: Multi dwg to single pdf?
Date Posted: 14.May.2009 at 13:19
Greetings,
I need to convert several dwg files into one pdf file.  I can print them...then scan them into a pdf with our scanner, but I'm looking for a program or another method to do this.
Anyone have any recommendations for programs or methods for converting muliple dwg files into a single pdf?
Thanks!!!
Posted By: msplcdykee69
Date Posted: 14.May.2009 at 18:40
I use a free PDf maker "PDF995"  and when I publish multiple pages, then I use full version of Adobe software to bind all the single drawings together into a multiple page pdf.  that is the most simple way we do it here.
Engineering Manufacturing Medical Cables/Adjunct Instructor Engineering Graphics/Engineering Computations and Careers
msplcdykee69@yahoo.com
Shawn
Posted By: Prasadg2007
Date Posted: 15.May.2009 at 14:08
Use the Adobe Acrobat Reader 9.0 Pro Version for Convert Multi Dwg to PDF......
gprasadnzb@gmail.com
Posted By: tkelly
Date Posted: 15.May.2009 at 16:53
I use PDFill PDF editor. It's really quick and secondly it does lot of functions other than just merging PDF. Have a look at it. Search it through Google
Tom
http://www.indovance.com - www.indovance.com
Posted By: AmerieWhite
Date Posted: 18.May.2009 at 06:57
I'm using AutoDWG PDF Convertere, it is cool and I can convert drawing into just one PDF by using my CTB files to load line weight and colors.
It'here: http://www.autodwg.com/PDF/ - http://www.autodwg.com/PDF/
Amerie White
Posted By: Vladimir Michl
Date Posted: 18.May.2009 at 08:00
You don't need any additional software - AutoCAD can publish multiple DWG files to a single PDF.
See e.g. the "related tip":
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5677 - http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5677
Vladimir Michl (moderator)
https://www.linkedin.com/in/vmichl/" rel="nofollow - LinkedIn , Autodesk Expert Elite
Posted By: stevod
Date Posted: 26.May.2009 at 19:53
Acrobat can also create a .pdf package, which I think looks nicer than having them all in a single pdf.
S
Stephen
http://www.residenceinteriordesign.com - Residence Interior Design London
Associate Member http://www.bida.org/member/residence-interior-design-limited/about - BIDA
