Print Page | Close Window
Spring or Helix Command
Printed From: CAD Forum
Category: EN
Forum Name: AutoCAD
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2036
Printed Date: 04.Sep.2026 at 23:16
Topic: Spring or Helix Command
Posted By: sidhu412
Subject: Spring or Helix Command
Date Posted: 23.May.2009 at 18:53
How can I create a spring in AutoCad 2006 where it can be created in AutoCad 2007 or later with Helix Command. But I am using AC 2006, So plz help me to do the said job.
Regards,
Sidhu
Posted By: AmerieWhite
Date Posted: 26.May.2009 at 15:29
You need to do version conversion from a lower CAD version to an upper. You can try AutoDWG DWG DXF converter at
http://www.autodwg.com/DWG_DXF_Converter/ - http://www.autodwg.com/DWG_DXF_Converter/
Create your drawing in 2006 and then import this draiwng into this converter and generate high version CAD drawings.
Amerie White
