Print Page | Close Window
Auto CAD Map 3D 2008 Fatal Error?
Printed From: CAD Forum
Category: EN
Forum Name: Civil 3D, Map, InfraWorks
Forum Description: Discussion about mapping and GIS applications Map, Civil3D, InfraWorks, MapGuide and Raster Design
URL: https://www.cadforum.cz/forum_en/forum_posts.asp?TID=205
Printed Date: 15.Oct.2026 at 19:36
Topic: Auto CAD Map 3D 2008 Fatal Error?
Posted By: Jim F&P
Subject: Auto CAD Map 3D 2008 Fatal Error?
Date Posted: 23.Oct.2007 at 23:05
Our Company just started using the 2008 Version - I am now unable to insert map images. Once I use the"mapiinsert" command or from the map menu - it will insert the image and once I try to zoom extents it will give me the following error message:
"Fatal Error: Unhandled Access Violation Reading 0x0000 Exception at 61b351d6h."
I go back to the 2007 version and it works fine? I have upgraded to SP1 and also installed 'raster_design_2008_oe.exe"
Looked on Autodesk help page with no success - Any suggestions?
Jim M
Posted By: Jim F&P
Date Posted: 30.Oct.2007 at 16:39
Found a fix from Autodesk -
Somehow the previous version of the "AdImaging.dll" was corrupted or would not work with my configuration.
I have a new version of this file 17.1.219.2 which also can be requested from Autodesk. You just replace the old one which is found in your "C:\Program Files\AutoCAD Map 3D 2008" folder.
If you need a copy of this file please send me an email - mailto:j.moser@fehrandpeers.com - j.moser@fehrandpeers.com
